Unable to get dataminer templates in Visual Studio 2022 for project
Solved2.51K views16th October 2024#automationscript Templates
Apurva Tandon [DevOps Advocate]1.73K 3rd October 2024 0 Comments
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 16th October 2024
Davor Joleski [DevOps Enabler]743 Posted 8th October 2024 0 Comments
Yes i have thought's like you the think  is diffrence from 2019 and 2022 ,2019 have templates while creatin on 2022 direct is connected ,so  i was confused too if u can connect everything protocol and scirpt with DIS and display the parameters on Dataminer Cuber you are okej,try this,if don't try search on Nuget menager the problem you describe the detail on browser or AI that would help i think nuget is general
Davor Joleski [DevOps Enabler] Answered question 8th October 2024
You are viewing 1 out of 6 answers, click here to view all answers.
