Unable to get dataminer templates in Visual Studio 2022 for project
Solved2.51K views16th October 2024#automationscript Templates
Apurva Tandon [DevOps Advocate]1.73K 3rd October 2024 0 Comments
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 16th October 2024
Davor Joleski [DevOps Enabler]743 Posted 7th October 2024 1 Comment
first connect  to the DIS and Domain stuffs then try update maybe that would fix
Apurva Tandon [DevOps Advocate] Posted new comment 8th October 2024
Apurva Tandon [DevOps Advocate] commented 8th October 2024
Yes, I am able to import a protocol and do another stuff when connected to agent, but on creating new fresh project the dataminer templates are not shown and same error on templates update as in image for DIS settings
You are viewing 1 out of 6 answers, click here to view all answers.
