Unable to get dataminer templates in Visual Studio 2022 for project
Solved2.51K views16th October 2024#automationscript Templates
Apurva Tandon [DevOps Advocate]1.73K 3rd October 2024 0 Comments
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 16th October 2024
Davor Joleski [DevOps Enabler]743 Posted 7th October 2024 1 Comment
HI,then try do delete from extension dataminer delete and then again install update all things
and then close VS whole and start again you should have it then that was worked for me i don't know why should make problem
Apurva Tandon [DevOps Advocate] Posted new comment 8th October 2024
Apurva Tandon [DevOps Advocate] commented 8th October 2024
Hi Davor,
Unfortunately, it didn’t worked
I did remove the dataminer extension and installed again, but on creating new project no dataminer template is shown and in setting on DIS in template it shows the same error as I pasted in the screenshot in my original question.
You are viewing 1 out of 6 answers, click here to view all answers.
