Unable to get dataminer templates in Visual Studio 2022 for project
Solved2.53K views16th October 2024#automationscript Templates
Apurva Tandon [DevOps Advocate]1.73K 3rd October 2024 0 Comments
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 16th October 2024
Davor Joleski [DevOps Enabler]743 Posted 4th October 2024 1 Comment
you can reinstall i had the same problem and its worked for me
Apurva Tandon [DevOps Advocate] Edited comment 7th October 2024
Apurva Tandon [DevOps Advocate] commented 7th October 2024
Hi I did reinstall but still its not showing Dataminer templates and I am on Windows 11.
You are viewing 1 out of 6 answers, click here to view all answers.
