Unable to get dataminer templates in Visual Studio 2022 for project
Solved2.54K views16th October 2024#automationscript Templates
Apurva Tandon [DevOps Advocate]1.73K 3rd October 2024 0 Comments
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 16th October 2024
Michiel Oda [SLC] [DevOps Advocate]3.84K Posted 3rd October 2024 3 Comments
Hi Apurva
Could you check if you have the latest version of Visual Studio 2022?
Apurva Tandon [DevOps Advocate] Posted new comment 7th October 2024
Apurva Tandon [DevOps Advocate] commented 3rd October 2024
Hi yes, I have latest version
Microsoft Visual Studio Professional 2022 (64-bit) – Current
Version 17.11.4
Michiel Oda [SLC] [DevOps Advocate] commented 4th October 2024
I have the same version and have no troubles. Are you on the latest DIS release (3.1.3)?
Apurva Tandon [DevOps Advocate] commented 7th October 2024
Yes, I am on the latest one
You are viewing 1 out of 6 answers, click here to view all answers.
