Trigger script depending on variable in LCA
770 views26th June 2026low code app trigger
Stijn Declerck [SLC] [DevOps Advocate]834 26th June 2026 0 Comments
Is it possible in a low code app to let the execution of a script depend on a variable of type boolean? We have a use case where a "safe mode" setting should prevent actions from happening when someone triggers them by accident. It would be applicable on multiple components and easy for us to use the same variable for that.
Wout Mahieu [SLC] [DevOps Catalyst] Answered question 26th June 2026
Wout Mahieu [SLC] [DevOps Catalyst]12.48K Posted 26th June 2026 0 Comments
Hi Stijn,
There is currently no such thing as 'conditional actions'. Instead, you could have an input parameter in the script and pass that variable value to it. Then the script can decide what to do based on the input.
