Toggle component as a filter
300 views30th September 2026
Sion Aspinall156 30th September 2026 0 Comments
I have a Query that has a column called Match that is a boolean column. I'm trying to add a filter to the column when I build the query in low code app and link it to a boolean toggle component which it allows me to do but using the toggle doesn't seem to change the value (true or false). Is what I'm doing legitimate? I'm also not really sure on the toggle component use cases. I've rarely succeeded in using it in a low code app.
Wout Mahieu [SLC] [DevOps Catalyst] Answered question 30th September 2026
Wout Mahieu [SLC] [DevOps Catalyst]12.47K Posted 30th September 2026 0 Comments
Hi Sion,
I tried this myself and it indeed doesn't seem to work correctly at the moment. As a workaround, you can use a query filter component which will have a built-in filter for the boolean columns available.
We will let you know here once the issue has been fixed.
