The ‘Use Polling (Connection)’ Setting
Solved30.63K views11th July 2023
Ken O'Connor592 1st February 2022 0 Comments
Very simple question.. What is the setting 'Use Polling (Connection)' used for? Does it or can it enhance performance/user experience?
Ive Herreman [SLC] [DevOps Enabler]14.43K Posted 1st February 2022 0 Comments
Hi Ken,
You can find some more details on what this is on this help page.
The default interval when using polling is 1000ms (1 second).
There aren't really any valid reasons to increase the polling, as it's unlikely that the users working with the system will notice any difference.
You could potentially decrease the polling interval, to save some network bandwidth, but the difference will be negligible and would only make sense when connecting to your DataMiner system over a metered connection.
Ive Herreman [SLC] [DevOps Enabler] Answered question 1st February 2022
