The  problem with option bidirectional on the graf between nodes
Solved1.82K views3rd June 2024
Jaroslaw Burtny [DevOps Member]756 31st January 2024 2 Comments
Hi All.
I noticed a strange case in my graph between nodes for connections edges.
I have an unselected connection in two directions and the graph draws two connections for me
The  option bidirectional not selected as below.
Where could be the problem ?
Big thanks for help.
Br.
Jarek
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 3rd June 2024
Marieke Goethals [SLC] [DevOps Catalyst] commented 25th April 2024
Hi Jarek,
Do you still need help with this question? If not, could you select the answer (using the ✓ icon) to indicate that the question can be closed?
Marieke Goethals [SLC] [DevOps Catalyst] commented 3rd June 2024
As this question has been inactive for a long time, I will now close it. If you want further assistance, could you post a new question?
Steve Purcell [SLC] [DevOps Advocate]2.69K Posted 1st February 2024 2 Comments
Hi Jarek, There are a couple things I believe you would need to check, if I understand what you are saying.  I believe you are trying to identify why there are no connections between AppearTV55 and TMux28 like there is for TMux18, which has connectivity to both Appear elements.
If that is the case then:
Are there DCF connections between AppearTV55 and TMux28.
If not then add the connections between AppearTV55 and TMux28.
Does your GQI query ‘DCF-Between TMUX and AppearTV’ show the expected data if brought out to a ‘table shape’ rather than ‘Node Edge Graph’?
If no, then the query needs to be modified to include the data for AppearTV55 and TMux 28.  This may require adding another table join level.  If you can share your query we would have a better idea.  The following image shows the GQI query we use on the demo system and the results in table format.
The following shows the linkage between the Interfaces table and Connectivity properties to populate the edge lines in the Node Edge Graph.
Jaroslaw Burtny [DevOps Member] commented 1st February 2024
Hi Steve.
Maybe the ports on both sides of the devices are full-duplex and when I create a connection on the graf I have two lines between two nodes ??
And I need to filter for example by source port at query…
Could this have happened ?
Br.
Jarek
Steve Purcell [SLC] [DevOps Advocate] commented 2nd February 2024
Hi Jarek,
I added to the answer above to show the linkage between the connectivity properties of the element and the element interfaces table. This connectivity has to be present on both elements making the connection. I believe you need to verify this configuration first, then we can look at the queries if needed.
