The problem with displaying trends on the chart
Solved1.65K views4th June 2024
Jaroslaw Burtny [DevOps Member]756 4th February 2024 0 Comments
Hi All
I have a problem with displaying chart trends.
On the right side, the table displays channels, the number of CC errors and their trends, but on the left side, after selecting a channel, you cannot see the trends na chart
I click on trends in the table
an I can see tren for errors CC
All parameters are in the same table fot chart.
Where is the problem.
From the DMA monitoring it has trends, but from the bashboard chart I don’t have trends for CC errors.
Big thanks for naswer.
Br.
Jarek
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 4th June 2024
Steve Purcell [SLC] [DevOps Advocate]2.37K Posted 6th February 2024 0 Comments
Hi Jarek,
For the Line & Chart area to function it needs to be aware of Parameter, Element, Timeframe and if a table parameter, then Index also.
Following is a screenshot with the parameters necessary, in this case I am using a pick list for MS Platform Elements, then the timeframe at the top, plus the user selection of the Memory Usage row as feeds into the Line&Chart shape filter.  The shape Data field (Memory Usage) was selected from the Parameters selection by Protocol rather than element as I am using a pick list for the particular element.
Hope this helps.
Steve
