The problem of work driver DEV1951 at chassis switch DEV1953
Solved877 views18th July 2024
Jaroslaw Burtny [DevOps Member]756 27th February 2024 2 Comments
Hi All.
Do you know the problem of DEV 1951 drivers for the DEV 1953 Universal Switch Chassis device?
I have information that DEV 1951 drivers should work for the DEV 1953 device but
I can’t get more information than on the screenshots as below :
Do we need other drivers for additional cards in this chassis? Does this driver is very old and it doesn’t supports additional cards in this chassis? . Maybe I need an additional configuration settings in this chassis DEV 1953?
Maybe someone has already had such a problem with DEV switch chassis devices ?
Big thanks for help.
Br.
Jarek
Marieke Goethals [SLC] [DevOps Catalyst] commented 4th June 2024
I see that this question has been inactive for some time. Have you been able to solve this based on Jordy’s answer? If yes, could you select the answer to indicate that this question is resolved?
As this question has now been open for a long time and there has been no further reaction from you, I will now close it. If you still want more information about this, could you post a new question?
Jordy Bekaert [SLC] [DevOps Advocate]2.03K Posted 28th February 2024 0 Comments
Hi Jaroslaw, from our knowledge base I could notice that the DEV Switch SNMP connector was deployed earlier for 1953 switches. The latest driver versions are also more recent. Perhaps it would be interesting to request your Skyline squad for a trial of this connector?
