The problem from menu Live Diagnostic in Cassandra Reaper after ugrade form ver. 3.2.0 to 3.7.1
Solved1.76K views19th June 2025
Jaroslaw Burtny [DevOps Member]756 8th January 2025 1 Comment
Hi All.
I noticed a small problem when updating Cassandra Reaper from version 3.2.x to version 3.7.1
I can’t get to the Live Diagnostic tab ….the browser is processing something constantly on this page.
in the previous version there was no such problem..
Cassandra and Reaper processes work properly.
Below is the error from the browser
Big thanks for help.
Br.
Jarek
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 19th June 2025
Jaroslaw Burtny [DevOps Member] commented 8th January 2025
I noticed that after some time, my connection to the cluster via the browser is disconnected and I have to log in to Cassandra Reaper again to reconnect to the cluster
Alexander Gorbunov [SLC] [DevOps Advocate]1.27K Posted 9th January 2025 0 Comments
Hi Jarek,
We have an in-house setup where we run Reaper 3.7.0. Live Diagnostic is also not loading there.
Reaper documentation clarifies that Live Diagnostic feature requires the option diagnostic_events_enabled to be enabled on the Cassandra node. So possibly the page is not responding because of the missing configuration on the database side.
Aside from that, I would like to point out that the “Live Diagnostic” link in Reaper’s Web UI has the label “beta” next to it, from which I would assume this feature is still under development and issues in Reaper itself may occur.
For the DataMiner maintentance purposes, this feature is not required. As long as you have access to “Clusters”, “Schedules” and “Repairs”, this is sufficient to ensure Reaper is doing its job.
Jaroslaw Burtny [DevOps Member]756 Posted 9th January 2025 0 Comments
I can see errors when the browser connects to Diagnostic Events
Jarek
Jaroslaw Burtny [DevOps Member] Answered question 9th January 2025
