Tables in Elements: customize Column Headers values?
Solved2.96K views14th February 2024adl2099 column headers Column Manipulation
Alberto De Luca [DevOps Enabler]5.72K 13th February 2024 0 Comments
Sorry if this might be a basic question - is there a way to configure the value in the column "headers" of a given element table?
(Just looking to avoid reinventing the wheel if this feature is already available or in roadmap)
This one below is an example from the Microsoft protocol:
normally, a value gets calculated for the header line, by default...
Is there a way to configure this, so that I can get the "Total (SUM)" of all values in a given column?
Could I get to configure the header to display either the Max or Min value across all the rows?
And ideally, is there a way to export that reading via a dashboard or in a VISIO to build some visuals associated with relevant parameters, possibly without the need to recalculate the value?
Any steer will be helpful!
Thanks
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 14th February 2024
Alberto De Luca [DevOps Enabler]5.72K Posted 13th February 2024 1 Comment
I can retrieve a "SUM" option in this CUBE section - what about the min/MAX?
Does the latter need the option added at protocol layer?
Tom Waterbley [SLC] [DevOps Enabler] Posted new comment 13th February 2024
Tom Waterbley [SLC] [DevOps Enabler] commented 13th February 2024
Hi Alberto. Yes, that needs to be defined on protocol level.
