table and Visio info and color
Solved2.30K views23rd August 2024table Visio
Cedric Buerfent224 19th April 2024 2 Comments
Dear,
in “..edit in Visio”:
I want to display one cell value of table in MS Visio.
Is that possible? How can I achieve it? (Element + Parameter?)
I want also to display just an alert (color) of one column (e.g. DOWN=red etc)
of the elementtable. Possible?
Do you have maybe some code (visio Element, Parameter)?
Thanks and best regards Cedric Buerfent
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 23rd August 2024
Hi Cedric,
I see that this question has been inactive for some time. Do you still need more information for this? If not, could you select Jarno’s answer to indicate that the question is resolved?
Marieke Goethals [SLC] [DevOps Catalyst] commented 23rd August 2024
Jarno Lernou [SLC] [DevOps Enabler]6.08K Posted 19th April 2024 4 Comments
Hi Cedric,
That is pretty straightforward in Visio. You can find examples over here: Basic shape data field configuration. Of course, you do need to know the primary key or the display key of the desired row.
There is also a nice tutorial on this topic: Getting started with basic shapes | DataMiner Docs. The only difference is that you should include the aforementioned key in your Parameter shape data.
Kind Regards,
Jarno
Cedric Buerfent commented 19th April 2024
Ok I ll try out. Thanks.
Suppose I have this Element:
Element: 5909/555
Ids:
ID 100 : IfTable
ID 101 Index
ID 102 Interface Name
ID 103 TX Capacity
Do you have examples for:
– How can I display one interface name matching a prefix? (latest match wins?)
– How can I display all interfaces names matching a prefix? (a list)
– How can I display the “TX Capacity” with “Interface Name = dtm1:5” (a reference)
Regards Cedric
Cedric Buerfent commented 14th May 2024
any news on this one?
Jarno Lernou [SLC] [DevOps Enabler] commented 14th May 2024
Hi Cedric, I had overlooked your comment. I’m sorry for this.
Typically the interface name is part of your display key. I assume this is also the case for the connector that you are using.
Answer: We do have placeholders, but it will return the first match that it gets.
The shape data ‘Parameter’ holds the Parameter ID together with the display key, e.g. Paramater : 102,eth*
Not that easy but should be possible. The following placeholder can return a whole column (seperated with the | character). On top of that, you can use RegexReplace to do the filtering.
https://docs.dataminer.services/user-guide/Basic_Functionality/Visio/reference/Placeholders_for_variables_in_shape_data_values.html#paramdmaidelementidparameterid
https://docs.dataminer.services/user-guide/Basic_Functionality/Visio/reference/Placeholders_for_variables_in_shape_data_values.html#regexreplacexyz
I’m not sure if I fully understand this question here. You can use the answer from the first question for this. The index can contain ‘dynamic’ values such as a reference to a property, parameter or session variable.
Kind Regards,
Jarno
