System Requirements for DxM’s
Solved1.71K views5th July 2023Dataminer Extension Module
Tim Vandenbruwaene [SLC] [DevOps Member]2.24K 11th May 2023 0 Comments
When installing all DxM's on your DataMiner node:
  • Does this impact what the minimal system requirements are for the DM server? (https://community.dataminer.services/documentation/dataminer-system-requirements/)
  • If a DxM uses a significant amount of memory/CPU, can this impact the performance of the DataMiner software on the same server? Are their limitations on how much resources the DxM can consume?
  • Can a DxM be installed on a server that doesn't have DataMiner installed, but has connection to DataMiner?
Koen Annys [SLC] [DevOps Advocate]144 Posted 11th May 2023 0 Comments
connecting to dataminer.services can be done via a DMZ setup and via a proxy server. In those cases some DXMs need to be on the DMZ or proxy server and not on a DataMiner Agent.
An overview is available here
Separate cloud packs for those setups are available since recently , can be found here.
Koen Annys [SLC] [DevOps Advocate] Answered question 11th May 2023
