System Requirement Specs – DM 10.4//DM10.5 & Cassandra 4.x with OpenSearch
Solved840 views22nd April 2025adl2099 compute requirements DMA on-premise
Alberto De Luca [DevOps Enabler]5.36K 20th March 2025 0 Comments
Quick one, for DOJO gurus, pls:
is there any doc still available for System Requirements in DM 10.4/10.5 & Cassandra 4.x?
(e.g. similar to https://community.dataminer.services/wp-content/grand-media/application/SLC_SM_DataMinerSystemRequirements_REV045.pdf )?
Alternatively, when referring to the Compute Requirements Page, are there any recommendations when a virtualization layer is needed to run newer Linux-based Cassandra on premise?
Thinking to leverage VMs in order to install both Cassandra & OpenSearch in environments where STaaS would not be an option.
Thanks
Arunkrishna Shreeder [SLC] [DevOps Enabler] Selected answer as best 22nd April 2025
Arunkrishna Shreeder [SLC] [DevOps Enabler]4.28K Posted 21st March 2025 0 Comments
Hi Alberto,
I believe the documentation in DataMiner Compute Requirements | DataMiner Docs still holds even if you use VMs for your databases.
Just ensure you follow the recommendations mentioned here for your VMs too.
The most important point here is the disk throughput which is mentioned in the link; as long as you meet the numbers mentioned in the documentation, there shouldn't be any issues.
This page also covers system requirements for DataMiner to work seamlessly, irrespective of using 10.4 or 10.5.
