System Cache for central DB
Solved1.23K views11th August 2022central database
Jeroen Geldhof [SLC] [DevOps Enabler]5.49K 11th August 2022 0 Comments
It’s been a few months that a central DB has not been accessible.
The Central DB configuration in Cube has now been disabled.
Is it correct that the offload files are under Skyline DataMiner\System Cache\Offload\  ?
Is it sufficient to delete that folder to clear all these offload files?
Jeroen Geldhof [SLC] [DevOps Enabler] Selected answer as best 11th August 2022
Gellynck Jens [SLC]2.71K Posted 11th August 2022 0 Comments
Hi Jeroen,
Deleting that folder on all agents should indeed be sufficient.
