switch between eventing and polling on specific cube
Solved1.52K views11th October 2023
Erik Severiens40 11th October 2023 0 Comments
In the training video (getting started) you can switch from eventing to polling to prevent the annoying wait time/firewall issue popup.
This feature (all settings) seems to have disappeared in cube settings.
How to alter this setting for a specific cube.
Bert Vandenberghe [SLC] [DevOps Enabler] Selected answer as best 11th October 2023
Ive Herreman [SLC] [DevOps Enabler]14.55K Posted 11th October 2023 1 Comment
Hi Erik,
Please find a screen capture below showing how this can be done.
Erik Severiens commented 11th October 2023
Hello Ive, thanks it worked perfectly.
