Stream Viewer: Element not known yet
Solved2.21K views14th July 2023SNMP stream viewer
Alex Johnson [SLC] [DevOps Advocate]921 25th April 2022 0 Comments
When testing snmpv1 and snmpv2, I've been occasionally getting a strange streamviewer message:
This happens when uploading a new protocol (eg: copying and pasting) where the previous protocol was snmpv1 and the new one is snmpv2. The funny thing is, when I switch the version back to a previously released version that uses snmpv1 and then back to the version i'm working on, the stream viewer error goes away.
The customer also reported seeing this error on a few elements when setting an snmpv2 version to production from a previous version that uses snmpv1.
What does this error mean? Is it a software issue? We are on DM 10.2.3.0-11516.
João Severino [SLC] [DevOps Enabler]14.78K Posted 4th May 2022 0 Comments
Hi Alex,
As Wouter mentioned, this is indeed an error that happens when SLSNMPManager does not know about the existence of a certain element.
In order for it to know about an element, at startup, DataMiner tries to register the element with the correct SNMP manager but since SNMPv1 is incompatible with SNMPv2 for some polling options an issue arises since the element still thinks it is SNMPv1 and the connector "asks" for SNMPv2.
Due to the incompatibility, the registration process fails, and once the element starts polling it will behave in a very similar manner as to when an element is still starting up.
Just a restart will not be enough, you will need to edit the element and make sure the connection(s) have SNMPv2 or SNMPv3, and then click 'Apply' to make those settings take effect.
João Severino [SLC] [DevOps Enabler] Edited answer 4th May 2022
