Stream Viewer Detailed Documentation and Groups
Solved1.81K views22nd September 2023
Ken O'Connor676 20th September 2023 0 Comments
Is there a definitive list of Stream Viewer Groups and what they are used for? Is there more detailed documentation for Stream Viewer?
Thanks
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 22nd September 2023
Tom Waterbley [SLC] [DevOps Enabler]10.29K Posted 20th September 2023 1 Comment
Hi Ken,
The groups that are shown in the stream viewer depend on how they are defined in the connector itself. They show the data that is retrieved in each particular group, but this will be different in each connector. Unfortunately there is no documentation available about what is being polled in each group in a connector.
More general information about the stream viewer itself can be found here.
Laurens Moutton [SLC] [DevOps Enabler] commented 20th September 2023
Indeed, there is also an “Undefined” group that is used for data that enters ad hoc, for example if the connection type is smart-serial. In such case a response does not belong to a pair or group and that incoming data is then placed under the undefined group.
Ken O'Connor676 Posted 20th September 2023 0 Comments
Thanks Tom
Ken O'Connor [DevOps Member] Answered question 20th September 2023
