start element failed – hr-0x80070057
Solved1.31K views7th March 2023
Syed Taj uddin [DevOps Member]403 6th March 2023 1 Comment
Hi Team
when i start the element its giving error "start element failed", please find the below logs FYR.
2023/03/06 12:17:12.621|SLDataMiner.exe - DEC-1 Main@2454-TAS|10268|CElement::SetState|DBG|0|** Setting state finished.
2023/03/06 12:17:12.621|SLDataMiner.exe - DEC-1 Main@2454-TAS|10268|CElement::CreateObjects|INF|-1|** Creating objects for element DEC-1 Main@2454-TAS (440)
2023/03/06 12:17:12.621|SLDataMiner.exe - DEC-1 Main@2454-TAS|10268|CElement::Start|INF|-1|** Creating objects for element DEC-1 Main@2454-TAS (440)
2023/03/06 12:17:13.438|SLDataMiner.exe - DEC-1 Main@2454-TAS|10268|CElement::InitializeProtocol|ERR|-1|CreateIProtocol failed with The parameter is incorrect.. (hr = 0x80070057)
2023/03/06 12:17:13.438|SLDataMiner.exe - DEC-1 Main@2454-TAS|10268|CElement::Start|ERR|-1|CreateObjects for Element DEC-1 Main@2454-TAS failed with The parameter is incorrect.. (hr = 0x80070057)
2023/03/06 12:17:13.438|SLDataMiner.exe - DEC-1 Main@2454-TAS|10268|CElement::SetError|ERR|0|** Setting error : Creating element-objects for DEC-1 Main@2454-TAS failed. The parameter is incorrect. (hr = 0x80070057)
2023/03/06 12:17:13.438|SLDataMiner.exe - DEC-1 Main@2454-TAS|10268|CElement::Activate|ERR|0|Start failed. The parameter is incorrect. (hr = 0x80070057)
2023/03/06 12:17:13.438|SLDataMiner.exe - DEC-1 Main@2454-TAS|10268|CElement::SetState|DBG|0|** Setting state from 1 to 10 (RealState = 4)
2023/03/06 12:17:13.438|SLDataMiner.exe - DEC-1 Main@2454-TAS|10268|CElement::Activate|DBG|0|** Alarm template : Template1
2023/03/06 12:17:13.438|SLDataMiner.exe - DEC-1 Main@2454-TAS|10268|CElement::Activate|DBG|0|** Trend template : <No Trending>
2023/03/06 12:17:13.438|SLDataMiner.exe - DEC-1 Main@2454-TAS|10268|CElement::InitializeLock|DBG|0|** Initializing lock status
2023/03/06 12:17:13.438|SLDataMiner.exe - DEC-1 Main@2454-TAS|10268|CElement::InitializeLock|DBG|0|** Not locked.
2023/03/06 12:17:13.438|SLDataMiner.exe - DEC-1 Main@2454-TAS|10268|CElement::NotifyRedundancy|DBG|0|** Redundancy Changes
2023/03/06 12:17:13.438|SLDataMiner.exe - DEC-1 Main@2454-TAS|10268|CElement::NotifyServiceTriggers|DBG|0|** Service Triggers
2023/03/06 12:17:13.438|SLDataMiner.exe - DEC-1 Main@2454-TAS|10268|CElement::NotifySNMPManagers|DBG|5|Notifying SNMPManagerV2 of active 35901/440
2023/03/06 12:17:13.438|SLDataMiner.exe - DEC-1 Main@2454-TAS|10268|CElement::NotifySNMPManagers|DBG|5|Notified SNMPManagerV2 of active 35901/440. The operation completed successfully. (hr = 0x00000000)
Syed Taj uddin [DevOps Member] Selected answer as best 7th March 2023
Wouter Demuynck [SLC] [DevOps Advocate] commented 6th March 2023
Is this error present for one specific element or does this occur for all elements?
The error code appears to indicate that the protocol/driver could not be initialized. Additional logs might be visible in the DataMiner and/or Errors logfiles.
Ana Pinho [SLC] [DevOps Member]1.42K Posted 6th March 2023 0 Comments
Hi!
I would say that a parameter on the XML is not properly defined.
If possible I would advise to run the DIS validator to check for errors.
