STaaS Migration Procedure for Multi-Agent Cluster with Separate Per-Agent Cassandra Nodes
Solved495 views3rd October 2025CassandraDB STaaS
6
Miguel Barquet [SLC] [DevOps Advocate]1.92K 2nd October 2025 0 Comments
Dear DataMiner Community,
We are preparing to migrate the historical data from a production DataMiner cluster consisting of 5 main agents, each configured with a dedicated failover backup agent (1+1 redundancy model), to Skyline’s STaaS. Our intention is to adhere to the standard migration procedure outlined in the official documentation: Migrating existing data to STaaS.
Current Database Architecture:
  • DataMiner Installation: Hosted on the C: drive across all agents.
  • Cassandra Deployment: Collocated in the DataMiner server, running on D: drive
  • ElasticSearch Configuration: A single, standalone ElasticSearch node that serves all agents in the cluster for indexing and search functionalities.
  • Data Scope: The migration encompasses all historical data types (e.g., trending, alarms, custom data including DOM, SRM, and Analytics), with no specific exclusions planned at this stage.
Procedure Alignment:
Given our architecture with fully segregated Cassandra nodes per agent (as opposed to a consolidated cluster-wide Cassandra deployment), we seek clarification on the following:
  1. Direct Applicability: Does the standard procedure fully apply without modifications in this scenario, particularly regarding the coordination of data transfer across independent Cassandra nodes? For instance, will the migration script automatically handle ring-wide synchronization during the “Start Move to STaaS” and subsequent phases?
  2. ElasticSearch: How does the shared single ElasticSearch node factor into the process??
  3. Monitoring and Rollback: In a multi-agent setup, how can we best monitor progress granularly per storage type and agent?
Any insights, experiences from similar migrations, or references to additional resources would be greatly appreciated.
Thank you in advance for your expertise.
Miguel Barquet [SLC] [DevOps Advocate] Selected answer as best 3rd October 2025
Louis Lavens [SLC] [DevOps Member]469 Posted 3rd October 2025 1 Comment
Hi Miguel,
This procedure can also be used with your current setup. The migration script will detect that Cassandra has individual nodes and trigger the migration on each agent. It will also detect that Elastic is cluster-wide and trigger the migration once.
Progress can be monitored using the CloudStorageMigrationProgress script, as mentioned in the documentation. Each agent will report its progress.
As a reminder, you mentioned failover. Before starting the script, ensure that the main agent is active for each pair.
Kind regards,
Louis
Miguel Barquet [SLC] [DevOps Advocate] Posted new comment 3rd October 2025
Miguel Barquet [SLC] [DevOps Advocate] commented 3rd October 2025
Thanks, Louis.
