STaaS : Cube TTL settings
Solved1.88K views29th September 2023STaaS TTL
Wale Oguntoyinbo [SLC] [DevOps Advocate]4.03K 27th September 2023 0 Comments
Dojo,
Does STaaS take into account the time to live (TTL) settings in cube for database records ?
Wale Oguntoyinbo [SLC] [DevOps Advocate] Selected answer as best 29th September 2023
Baptiste Pattyn [SLC] [DevOps Advocate]5.85K Posted 29th September 2023 0 Comments
Hi
Now we just apply the default TTL at the moment but this is not configurable by the users.
The only exception for this is Real Time trending where the TTL of Cube will be taken into account for the data that is being returned.
