SRM – How to create silent booking with variable for resource assignment
Solved1.69K views21st December 2021silent booking SRM
Bruno Dias [SLC] [DevOps Member]2.39K 21st December 2021 0 Comments
In our platform, our resources are organized by Sites (which is a resource capability). Each resource belongs to a site.
Our intention is that when we create a booking, we select a site and all the resources are filtered by this capability.
So, we configured the following in the nodes of service definitions:
"Condition": "<A>",
"Value": [
"Label": "A",
"Type": "Operation",
"Value": {
"FirstOperand": {
"Link": "[var:Site]"
"Operator": "=",
"SecondOperand": {
"Link": "RESOURCE",
"Capability": "Site"
In the booking wizard, this is working fine.
Next step is to update our automation script that is creating bookings silenty. How can we pass the Site as input argument during the slient booking creation?
Bruno Dias [SLC] [DevOps Member] Selected answer as best 21st December 2021
David Pernes [SLC]90 Posted 21st December 2021 0 Comments
Hi Bruno,
To filter out resources silently based on "Site" parameter you'll have make use of  the group objects in the TryCreateNewBooking call present in the BookingManager.
On your automation script make sure to use the "IEnumerable<Group>" as input field to provide a filtering group.
Here is an example of a Group object creation:
var group = new Group
Name = "ProfileParameterName", // Profile Parameter Name should be "Site"
Type = FilterType.Capability,
NodeIds = new List<int>{4}, // Node Ids to apply the filter to.
SelectedLocation = "SiteToFilter", // for instance Lisbon / Izegem etc..
Label = "ProfileParameterName"// Profile Parameter Name should be "Site"
