Spectrum thumnails displaying round robin monitor points
Solved2.64K views11th July 2023spectrum analyzer Visio
Bernard Pichot [SLC] [DevOps Advocate]1.32K 18th January 2021 0 Comments
In order to display a spectrum thumbnail in Visio you should specify the following parameters
ParameterID|MonitorRef|ScriptVariable|MeasurementPointID|PresetName|SpectrumOptions
When the spectrum analyser is doing a round robin between several measurement points, what should be the syntax to refresh the visio thumbnail every time a new measurement point trace is available and then follow the round robin ?
Michiel Vanthuyne [SLC] [DevOps Advocate]4.79K Posted 20th January 2021 0 Comments
Hi Bernard, as Wouter and Miguel already indicated, this is not possible, and probably also not very useful as all 5 traces will be taken with short intervals, and then you will see always the same last trace until the next time the monitor runs.
However, you can probably provide a solution by making the MeasurementPointID reference dynamic and linking it to a session variable. If you also add buttons for the 5 measurement points setting this session variable, a user can choose for which measurement point he/she wants to see the last trace.
