Spectrum thumnails displaying round robin monitor points
Solved4.04K views11th July 2023spectrum analyzer Visio
Bernard Pichot [SLC] [DevOps Advocate]1.48K 18th January 2021 0 Comments
In order to display a spectrum thumbnail in Visio you should specify the following parameters
ParameterID|MonitorRef|ScriptVariable|MeasurementPointID|PresetName|SpectrumOptions
When the spectrum analyser is doing a round robin between several measurement points, what should be the syntax to refresh the visio thumbnail every time a new measurement point trace is available and then follow the round robin ?
Wouter Demuynck [SLC] [DevOps Advocate]7.08K Posted 19th January 2021 1 Comment
As far as I remember, this is not possible. The thumbnail always links to one trace result for one specific measurement point used by a monitor.
I don't think it would be very useful either, as for a monitor running once an hour and measuring a trace on 5 measurement points, you would see the 5 traces passing by around the hour and then see the same trace (last one measured) for the remainder of the hour.
Bernard Pichot [SLC] [DevOps Advocate] Posted new comment 19th January 2021
Bernard Pichot [SLC] [DevOps Advocate] commented 19th January 2021
Thanks Wouter,
in my use case the trace is updated every ~5 seconds that’s why it can make sense see the latest trace
