Spectrum thumnails displaying round robin monitor points
Solved4.03K views11th July 2023spectrum analyzer Visio
Bernard Pichot [SLC] [DevOps Advocate]1.47K 18th January 2021 0 Comments
In order to display a spectrum thumbnail in Visio you should specify the following parameters
ParameterID|MonitorRef|ScriptVariable|MeasurementPointID|PresetName|SpectrumOptions
When the spectrum analyser is doing a round robin between several measurement points, what should be the syntax to refresh the visio thumbnail every time a new measurement point trace is available and then follow the round robin ?
Miguel Obregon [SLC] [DevOps Catalyst]23.92K Posted 18th January 2021 2 Comments
Hi Bernard,
When you configure the monitor, you define how often the trace will be updated:
In the monitor you can define the script and the measurement point that will be used to update the trace.
Miguel Obregon [SLC] [DevOps Catalyst] Posted new comment 19th January 2021
Bernard Pichot [SLC] [DevOps Advocate] commented 18th January 2021
Thanks Miguel,
But during the round robin, the measurement point is changing continously so is there a way to specify that the visio should display the latest available trace whatever the measurement point/preset used ?
Miguel Obregon [SLC] [DevOps Catalyst] commented 19th January 2021
Hi Bernard, as far as I know this is not possible. The Visio shape was implemented to visualize a specific trace
