Spectrum default values
Solved1.14K views26th August 2024spectrum
Robbie Demaegdt [SLC] [DevOps Member]666 17th May 2024 0 Comments
How can we override the default settings in spectrum?
When creating or opening an element, it will always use these settings but the span is too big for the device and because of that the UI will not enable so we can’t change it.
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 26th August 2024
Miguel Obregon [SLC] [DevOps Catalyst]22.32K Posted 17th May 2024 2 Comments
Hi Robbie,
If I am not mistaken you could use the reserved ID params for the spectrum analyzer to set the default values. If you look at the spectrum simulation protocol (QAction 99), you will see the default values defined in this QAction are the ones displayed in the spectrum settings.
Hope it helps.
Robbie Demaegdt [SLC] [DevOps Member] commented 23rd May 2024
the DefaultValue and the Value tag aren’t working, doing a setparameter in a qaction after restart also doens’t work.
Seems like nothing is working when they are greyed out.
Miguel Obregon [SLC] [DevOps Catalyst] commented 3rd June 2024
Hi Robbie,
Is there a reason why they are greyed out? If there is no specific reason then please if you can contact Techsupport team to further investigate this behavior
