Solid color instead of degraded colors in alarms
Solved1.75K views11th July 2023
Gautier Chaty 7th June 2021 0 Comments
Hi everyone,
Does someone know if it is possible to change alarms color to use a solid color instead of degraded ?
Thanks,
Marlies Vandenberghe [SLC] [DevOps Member]2.98K Posted 7th June 2021 1 Comment
This can indeed be configured in your cube settings
If you go to your settings on top and go to “Data Display” you can disable the option “enable heat map on table parameters”. This should change the behavior that all cells have a solid color
Leander Druwel [SLC] [DevOps Member] commented 7th June 2021
More information can also be found on
https://help.dataminer.services/dataminer/#t=DataMinerUserGuide/part_1/GettingStarted/User_settings.htm&rhsearch=heat&rhhlterm=heat
