Socket binding issue in QA Device Simulator
Solved1.36K views7th October 2024
Andrea Ivkovic [SLC] [DevOps Advocate]392 7th October 2024 2 Comments
Hi Dojo community,
I have been working on generating a file that holds the dynamic data for the Driver Passport platform, but I have encountered the following issue in the QA Device Simulator:
I have created the simulation file according to the instructions: Realistic dynamic simulations | DataMiner Docs
What could be the cause of this issue?
Andrea Ivkovic [SLC] [DevOps Advocate] Selected answer as best 7th October 2024
Miguel Obregon [SLC] [DevOps Catalyst] commented 7th October 2024
Hi Andrea,
Can you check if the IP address attribute defined in the ‘Agent’ tag is set to the IP address of the PC/server where are you running the simulation? or can you change it to localhost (127.0.0.1) and confirm if that works?
If this doesn’t work, could you check that the port number defined in the attribute ‘Port’ is not being used by another process?
Andrea Ivkovic [SLC] [DevOps Advocate] commented 7th October 2024
Hi Miguel,
Thank you for your answer.
The ‘Agent’ tag is set to the IP address of the server. I have tried changing it to localhost, but the issue is still there.
The port does not seem to be in use by any other processes.
Stacey Van Colen [SLC] [DevOps Member]2.75K Posted 7th October 2024 1 Comment
Hi Andrea,
It could be that the port is being used on the server itself. So just try out a port which isn’t in use, e.g. 1611.
Kind regards,
Hi Stacey,
Changing the port to 1611 has solved the issue for me.
