SOAP client in automation script.
Solved1.70K views12th July 2023Automation SOAP wsdl
Manuel Gallardo [DevOps Advocate]791 28th September 2022 0 Comments
What's the best way to implement a SOAP client in an automation scripts in order to get info from another DMS via web services?
Thanks in advance!
Miguel Obregon [SLC] [DevOps Catalyst]22.85K Posted 28th September 2022 2 Comments
Hi Manuel,
Is there a specific reason why you are planning to use SOAP? Is it not an option to implement this client using the JSON API? You can find some examples in DataMiner Docs
Manuel Gallardo [DevOps Advocate] commented 29th September 2022
Hi Miguel, thanks for your response.
JSON API could be fine too but my doubt is related to how open the http connection and serialize/deserialize the request/response content.
Is there any library from SL to perform this actions or do I need to use standard C# libraries?
Miguel Obregon [SLC] [DevOps Catalyst] commented 29th September 2022
For serialization/deserialization you can use Newtonsoft.Json framework (https://www.newtonsoft.com/json). The corresponding dlls can be found in C:Skyline DataMinerProtocolScripts
