SNMP connection problem
Solved2.96K views24th October 2024
Davor Joleski [DevOps Enabler]743 21st October 2024 0 Comments
HI guys can someone tell me what's happening i set snmp connection but i don't know where can be the problem is it VendorOID DeviceOID  IntegrationIdor  something else i don't understand these terms
Davor Joleski [DevOps Enabler] Selected answer as best 24th October 2024
Davor Joleski [DevOps Enabler]743 Posted 22nd October 2024 2 Comments
2.
3.
question_plus: The code is below
Davor Joleski [DevOps Enabler] Posted new comment 23rd October 2024
Ive Herreman [SLC] [DevOps Enabler] commented 23rd October 2024
Using the code snippets above, I reconstructed your protocol and can confirm that it is fine. This means that the cause of the communication issues is not your protocol.
You indicated you’d like to monitor a switch or router, but based on your screenshots, you seem to be using the community strings configured on your server, instead of the community strings configured on the device you try to monitor.
Can you navigate to the web UI of your tp-link and check if SNMP is enabled and verify what the community string is? It’s the community string that you have defined on your remote device that you’ll need to enter in the element configuration window of dataminer.
Davor Joleski [DevOps Enabler] commented 23rd October 2024
Hi Ive thanks for your research and your help,as i found my model router tplink doesn’t support snmp,so i can’t take it,one more question if i can’t take the data why he give me the data oid like on picture .This router was in home,so i testing home,in work we have case Mikrotik so we need to take snmpv3 protocol pic below..
