Snippets Menu does not appear
589 views20th February 2026Snippets
Francisco Javier Pascual [DevOps Member]69 14th August 2025 1 Comment
Dear Dataminer Colleagues,
some time ago I have updated MS Visual Studio to version 2022 and installed DIS, NuGET packages and else, but the "Snippets" option doesn't appear in the right-click submenu. Everything is updated to the latest version. I can't find any documentation, Kata Videos, or some where else that mentions how to install the package if it doesn't appear. Could somebody give me some clue?
Thanks and keep Thundering!
Marieke Goethals [SLC] [DevOps Catalyst] Posted new comment 20th February 2026
I see that this question has been inactive for some time. Do you still need help with this? If not, could you select the most relevant answer (using the ✓ icon) to indicate that no further follow-up is needed?
Francisco Javier Pascual [DevOps Member]69 Posted 14th August 2025 1 Comment
Hi Thomas,
For the XML language, I think they're all there, but for the C# language, I suspect some aren't loading correctly. I've tested with both XML and C# files, and for neither, the snippet appears in the context menu. Calling snippets using the shortcut ctrl+k, ctrl+x works properly. Although for C# files not all snippets are available.
Thomas Cauwelier [SLC] [DevOps Advocate] Posted new comment 15th December 2025
Thomas Cauwelier [SLC] [DevOps Advocate] commented 15th December 2025
Hi Francisco,
Sorry for the delayed follow-up. It looks like I didn’t receive a notification for your reply.
Are you still experiencing this issue with snippets?
From your screenshots, Visual Studio appears to recognize the snippets correctly. It seems like the problem is specifically with the Insert Snippet context menu.
For C# files, you mentioned that not all snippets are available when using the shortcut. Could you let me know which specific C# snippets are missing, or share a screenshot or list for comparison? That could help me determine cause of the issue.
