Snippets Menu does not appear
587 views20th February 2026Snippets
Francisco Javier Pascual [DevOps Member]69 14th August 2025 1 Comment
Dear Dataminer Colleagues,
some time ago I have updated MS Visual Studio to version 2022 and installed DIS, NuGET packages and else, but the "Snippets" option doesn't appear in the right-click submenu. Everything is updated to the latest version. I can't find any documentation, Kata Videos, or some where else that mentions how to install the package if it doesn't appear. Could somebody give me some clue?
Thanks and keep Thundering!
Marieke Goethals [SLC] [DevOps Catalyst] Posted new comment 20th February 2026
I see that this question has been inactive for some time. Do you still need help with this? If not, could you select the most relevant answer (using the ✓ icon) to indicate that no further follow-up is needed?
Thomas Cauwelier [SLC] [DevOps Advocate]1.78K Posted 14th August 2025 0 Comments
Hi Francisco,
Could you check if you can open the snippets menu via the default Ctrl+k, Ctrl+x shortcut? Note: the snippets will only appear when editing cs or xml files.
Do the snippets appear in the Code Snippets Manager?
Thomas Cauwelier [SLC] [DevOps Advocate] Answered question 14th August 2025
