Smart Serial Port not being claimed by Element
Solved3.97K views4th November 2021SLPort SmartSerial
Jack Perrott-Webb52 24th June 2021 0 Comments
We have configured our element to listen on a smart serial port, but it does not seem to be receiving data. The device that posts to this port has errors of "No connection could be made because the target machine actively refused it".
Looking on the machine itself, I can see that the port is not open (using Resource Monitor), but all 5 instances of SLPort are running and no apparent errors in the logs.
Where would you start to investigate? Please note that it will be very challenging to install wireshark so any other suggested tips would be appreciated (but if this is the only way then so be it).
Recently upgraded from DM9.6.10 to DM10.1 CU2 (unsure if related, but other environments do not have the above issue)
Jack Perrott-Webb Selected answer as best 4th November 2021
Joey Vanhalst [SLC] [DevOps Advocate]2.18K Posted 24th June 2021 3 Comments
Hi Jack, Is this specific port opened in firewall?
Jack Perrott-Webb Posted new comment 24th June 2021
Jack Perrott-Webb commented 24th June 2021
Hi Joey. Yes, the port is open on this agent. The communication is going via localhost
Joey Vanhalst [SLC] [DevOps Advocate] commented 24th June 2021
In this case you configured “localhost” as IP Address when creating your element?
In this case, we use any – but we actually used a similar step to this to help diagnose. Thank you!
