SLSNMPAgent slow leak on 10.4 CU6 and reference value
Solved785 views18th April 2025
Roberto Pau22 5th November 2024 2 Comments
Hello everyone,
could someone share a good threshold value for the SLSNMPAgent process to trigger the restart of the agent/s running 10.4 CU6 release?
Thank you,
Roberto.
Marieke Goethals [SLC] [DevOps Catalyst] commented 30th January 2025
Robin Devos [SLC] [DevOps Advocate]2.82K Posted 5th November 2024 0 Comments
Hi Roberto
This can be handled in the same way as described here: SLDataMiner leak on 10.4 CU6 and reference value - DataMiner Dojo (use SLSNMPAgent instead of SLDataMiner.)
SLSNMPAgent is also a 32bit process, however you'll want to check the nominal memory usage via the Microsoft Platform element > Task Manager > VM Size of SLSNMPAgent (over x months).
Knowing this nominal memory usage, you'll be able to configure the alarm template properly and create a correlation rule which uses those alarms.
