SLNet Test and Save Connection issue
Solved1.91K views19th July 2023
Mert Ruyeras0 23rd February 2021 3 Comments
I was working on SLNet option where I login/connect using a valid username with password and the system prompts: Connection with SLNet has failed.
While I login using a valid username without a password and the system prompts: Connection with SLNet was successful.
Marieke Goethals [SLC] [DevOps Catalyst] Posted new comment 19th July 2023
Mert Ruyeras commented 23rd February 2021
I need to understand why this happen? If this is an issue or a bug?
Wouter Demuynck [SLC] [DevOps Advocate] commented 23rd February 2021
As extra info: this question is about the Options window of the Taskbar Utility application (DataMiner icon in the Windows taskbar notification area when directly logged into a DataMiner Agent)
Marieke Goethals [SLC] [DevOps Catalyst] commented 19th July 2023
As this question has been inactive for a long time, I have now closed it. If you want further assistance, could you post a new question?
Tom Van Bruaene [SLC] [DevOps Member]948 Posted 23rd February 2021 1 Comment
If either the Username or the Password field is left empty, we try to log in using the current windows user instead of using those credentials.
So if your current windows user has access to the DMA, that would explain this behavior.
Thanks Tom.
How about on my first screenshot where I use a valid username and password but the system prompts: Connection with SLNet has failed.
