SLAutomation – CurrentCulture and CurrentUICulture in Automation scripts
Solved2.86K views10th July 2023Automation Culture datepicker UI
David Pernes [SLC]90 1st October 2020 0 Comments
When I run an Automation script from my localhost DMA, I get the culture nl-BE and UI culture en-US.
I made all the necessary changes in the Windows environment and created a ConsoleApp2.exe that would simply print the current culture info and UI culture info.
In the picture above, you can see an output of the console app stating en-GB for both Culture and UI Culture.
In the Automation script I'm executing the same code and getting a different result.
I've restarted the Windows system and still get the same result.
I also made sure the DataMiner settings are set to English United Kingdom.
Where do Automation scripts collect their culture information from and how can I change it?
### Edit
Under the Region Settings there is a welcome screen and new user account settings.
In some other system we detected the same behavior:
By checking these check boxes, hitting OK and restarting Windows once we ran the Automation script again we could see matching cultures between cmd application and Automation script.
I suspect that automation scripts collect culture information not based on the Current Windows user but from either the Welcome Screen or New User Accounts.
Michiel Saelen [SLC] [DevOps Advocate]6.50K Posted 2nd October 2020 2 Comments
Hi David,
Can you evaluate your settings on your machine?
David Pernes [SLC] commented 2nd October 2020
In Region – Administrative and i see English (United Kingdom) (Culture)
In Language Preferences i see English (United Kingdom) (UI Culture)
These configurations match the command line presented in the initial post.
Michiel Saelen [SLC] [DevOps Advocate] commented 2nd October 2020
David I would expect that DataMiner would follow your settings, so if this is not the case you can open a ticket to tackle this.
