SLAlerter – Sound only?
Solved2.42K views12th October 2022SLAlerter
Ruben Vandepitte [SLC] [DevOps Advocate]2.41K 12th October 2022 0 Comments
Can the SLAlerter tool be configured in such a way that only a sound notification is triggered, but no balloon popup, in case alarms occur that match the configured filter(s)?
Jeroen Geldhof [SLC] [DevOps Enabler] Answered question 12th October 2022
Matthias Declerck [SLC] [DevOps Advocate]3.14K Posted 12th October 2022 1 Comment
Hi Ruben,
It is currently possible to auto-hide the balloon.
it looks like the minimum is 1000 msec (see first option).
I would suggest to create a task for Data Insights and explain your use story.
2 proposals: decrease the minimum of msec, or accept the value 0/-1 which translates to not showing the balloon.
Michaël Pincket [SLC] [DevOps Advocate] Posted new comment 13th October 2022
Michaël Pincket [SLC] [DevOps Advocate] commented 13th October 2022
The hidding and showing of the balloon is not determined by the “Automatically hide BalloonNotification” setting. It is determined by the Filter section in the settings. For each selected filter a balloon will be shown. Playing the sound is linked to the balloon as it influence the sound. e.g. if a sound starts to play and you close the balloon before the sound finised playing, it will stop playing the sound.
