Skyline Generic Aggregator element not found
Solved1.25K views10th November 2023aggregation Dashboards shapes
Sebastián Cuéllar [SLC] [DevOps Advocate]190 9th November 2023 0 Comments
Hello everyone,
I’m working with the Aggregation feature in the DataMiner Cube, and I need to link the aggregations created to a shape following the instructions in here: Linking a shape to an aggregation rule | DataMiner Docs but the Skyline Generic Aggregator element does not exist in the Elements folder in the DMA. The purpose of doing this is to retrieve those aggregations results to a Dashboard.
Does anyone now how I can solve this? Is there another way to get the values in the Dashboard?
Sebastián Cuéllar [SLC] [DevOps Advocate] Selected answer as best 10th November 2023
Miguel Obregon [SLC] [DevOps Catalyst]22.41K Posted 9th November 2023 0 Comments
Hi Sebastian,
In order to see the aggregation rules in the dashboard app, you will need to locate the aggregation rule in a folder. See example below:
Can you double check that the element folder exists in C:\Skyline DataMiner\Elements folder? I just double checked and I could find the folder with the following name: Skyline Generic Aggregator DMAID
Hope it helps.
