Show a popup/toast inside a Cube View from a correlation-triggered Automation?
Solved861 views12th September 2025#automationScipt Correlation popup page view
Daniel Silva [DevOps Advocate]262 10th September 2025 0 Comments
I have an Automation Script triggered by a correlation on a critical alarm. After it runs headless, I want operators to see a visual notice inside a DataMiner Cube View .
I tried a simple popup:
var ui = new UIBuilder { Title = "Info", RequireResponse = false };
ui.AppendBlock(new UIBlockDefinition { Type = UIBlockType.StaticText, Text = "Switch executed." });
engine.ShowUI(ui);
But when launched by correlation it fails with:
Error launching script: interaction is required to execute this script
Question: Is there a supported way to display a popup/toast/banner directly in a Cube View when the script is triggered by correlation? If yes, how can this be done?
Daniel Silva [DevOps Advocate] Selected answer as best 12th September 2025
Ive Herreman [SLC] [DevOps Enabler]14.55K Posted 11th September 2025 1 Comment
Hi Daniel,
Since your script is running headless, you’ll need to define which user should receive the pop-up.
You can accomplish this using the FindInteractiveClient method (for more details, see here).
Daniel Silva [DevOps Advocate] Posted new comment 12th September 2025
Daniel Silva [DevOps Advocate] commented 12th September 2025
Thanks, Ive — great tip on using FindInteractiveClient. Appreciate your response!
