Shortcut for “read all” in alarmtable
Solved447 views8th September 2026Alarmtable DMA Shortcut
Simon Steinkamp [DevOps Advocate]201 7th September 2026 0 Comments
Hi there,
Is there a shortcut (like "F12") to mark all alarms as read?
Thank you!!
Edith Lansens [SLC] [DevOps Member] Selected answer as best 8th September 2026
Miguel Obregon [SLC] [DevOps Catalyst]23.97K Posted 7th September 2026 1 Comment
Hi Simon,
I performed a small test and all the alarms are displayed as 'read' once you press Ctrl+A (you should click at least in one alarm first). Is this the information you were looking for?
Hope it helps.
Simon Steinkamp [DevOps Advocate] commented 7th September 2026
Oh wow. too easy.
Thank you!!
