sharing DevOps status on LinkedIn not showing current level
Solved1.77K views5th April 2023DevOps
9
Philip Argent [DevOps Advocate]1.07K 4th April 2023 0 Comments
I have notices some people when sharing their DevOps attestation of membership on LinkedIn, it shows their current level. I’m currently an advocate, but it always shows member when I share the certificate link.
Ben Vandenberghe [SLC] [DevOps Advocate] Selected answer as best 5th April 2023
Sebastiaan Dumoulein [SLC] [DevOps Enabler]14.46K Posted 5th April 2023 1 Comment
I also ran into this issue and apparently it’s due to the caching of images on the side of LinkedIn. They launched a tool, Post Inspector, that will help you clear the LinkedIn Preview cache.
This should be the workaround:
  1. Go to Skyline | Certificates | Search Certificate (dataminer.services).
  2. Enter and validate your certificate.
  3. Copy the URL “https://certificates.dataminer.services/Certificate/…”
  4. Go to Post Inspector (linkedin.com)
  5. Enter the URL you copied and click on Inspect.
  6. When the tool has finished running, you will see that the preview image has been updated.
  7. Click on the LinkedIn share button.
  8. Go to the LinkedIn sharing page and refresh it, you will see that the correct image is now displayed.
  9. Share your post.
Philip Argent commented 5th April 2023
Thanks Sebastiaan, that worked.
Ben Vandenberghe [SLC] [DevOps Advocate]9.64K Posted 4th April 2023 1 Comment
I believe this is a known issue Phil – let me check on that an confirm.
Ben Vandenberghe [SLC] [DevOps Advocate] Answered question 4th April 2023
Thanks Ben
