shared folder on failover using shared hostname
Solved1.84K views27th February 2023IDP Configuration shared folder shared hostname
Jeroen Geldhof [SLC] [DevOps Enabler]5.51K 4th January 2023 1 Comment
In IDP Configuration it's necessary to define working folders for the DMAs.
The DMA has a failover setup using a shared hostname.
Accessing the shared folder however does not work using that shared hostname.
I found online that other people also had problems with shared folders using an 'alias' hostname, but I'm struggling to find the solution.  I'm looking for a Windows expert familiar with these commands and what they do.
I'm also not sure what proposed methods are safe to use on a DMA.
https://serverfault.com/questions/861630/windows-10-hosts-file-alias-not-working-with-file-share
https://social.technet.microsoft.com/Forums/en-US/c8d005a6-917e-4873-aece-fc0aa327acd5/file-sharing-cannot-be-accessed-by-dns-alias-name
Jeroen Geldhof [SLC] [DevOps Enabler] Selected answer as best 27th February 2023
Jeroen Geldhof [SLC] [DevOps Enabler] commented 5th January 2023
I found a workaround by creating a shared folder on an external server and by mapping it as a network drive on both main and back DMA servers.
This seems to be accepted by the IDP Configuration, but let me know if there is a better way.
Marlies Vandenberghe [SLC] [DevOps Member]2.98K Posted 24th February 2023 1 Comment
Hi Jeroen,
i confirmed with the IDP team, this method should be just fine
Jeroen Geldhof [SLC] [DevOps Enabler] Posted new comment 27th February 2023
Jeroen Geldhof [SLC] [DevOps Enabler] commented 27th February 2023
thanks for confirming
