Shape Data – Info box color
Solved497 views5th November 2025
Cheryl Prescott [DevOps Advocate]144 7th July 2025 1 Comment
Hello.  In light/mixed mode, my View (visio) displays the info as black text on white background.  When in dark mode, you cannot read the text.  The shape data is Info, and the name/orbital slot of a satellite.  Can the background color be changed?
Cheryl Prescott [DevOps Advocate] Selected answer as best 5th November 2025
Miguel Obregon [SLC] [DevOps Catalyst]22.39K Posted 7th July 2025 1 Comment
Hi Cheryl,
You could link the colors in the Visio Drawing to the colors used in Cube theme:
Overview of page and shape options | DataMiner Docs
Hope it helps.
Cheryl Prescott [DevOps Advocate] commented 7th July 2025
Miguel -I'll check it out and let you know.
