Setting up Gitlab with cloud connection
Solved615 views27th June 2025GitLab versioning
Curtis Baiden [DevOps Advocate]574 26th June 2025 0 Comments
Has anyone been able to connect their DataMiner system to GitLab?
Curtis Baiden [DevOps Advocate] Selected answer as best 27th June 2025
Jarno Lernou [SLC] [DevOps Enabler]5.79K Posted 27th June 2025 0 Comments
Hi Curtis,
Yes, it is possible to connect a DataMiner system to GitLab. You can deploy an Automation script solution from a GitLab repository by using the Skyline DataMiner Deploy Action in a pipeline. To do this, you need to:
  • Create a dataminer.services key.
  • Add the key as a masked variable in the repository.
  • Add the Skyline DataMiner Deploy Action to a pipeline.
Deployment through the use of a docker deployment action | DataMiner Docs
Kind Regards,
Jarno
