Setting up Failover when Elastic is installed on a DMA
Solved2.80K views29th April 2021database Elastic Elasticsearch Failover
Alexander Gorbunov [SLC] [DevOps Advocate]1.28K 28th April 2021 0 Comments
We have a DMA where Elasticsearch has been already installed, but we don't use it - we don't have SRM or Jobs, and we haven't enabled indexing for alarms.
Now we need to create a failover pair with this DMA. I've read that Elastic doesn't work well in a 1+1 configuration, so what should we do to ensure a stable failover setup?
I've seen this question on Dojo: Elasticsearch failover with SRM - DataMiner Dojo
The difference in our case is that we don't need Elastic for any application, and the third server is not a feasible option. I would simply disable Elastic, but I'm not sure if this can be done.
Thanks.
Alexander Gorbunov [SLC] [DevOps Advocate] Selected answer as best 29th April 2021
Ive Herreman [SLC] [DevOps Enabler]14.81K Posted 28th April 2021 1 Comment
Hi Alexander,
What DataMiner version are you running?
You can disable elastic by removing its configuration from the db.xml file.
Alexander Gorbunov [SLC] [DevOps Advocate] Posted new comment 28th April 2021
Alexander Gorbunov [SLC] [DevOps Advocate] commented 28th April 2021
Hi Ive, we’re on version 10.1-CU1.
