Setting discreets with dependency parameter
Solved1.31K views28th August 2024
Harinee G [DevOps Member]202 15th July 2024 0 Comments
We have a set of dynamic propositions for each channel and we need to select a single proposition accordingly to make the api call. We have added dependency of "Available Proposition" in the "Proposition To Be Slated" parameter inorder to fetch the values.
We are unable to get it as a set of different discreets separately but receiving as a same value in the dropdown. Tried implementing the logic to populate dynamic discreet values from Qaction too but it isn't working either.
Any suggestions on this one please to get the values separately in the dropdown?
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 28th August 2024
Jens Vandewalle [SLC] [DevOps Advocate]9.85K Posted 15th July 2024 1 Comment
Hi Harinee,
This feature only works with a semicolon-separated list of items as described in dependencyId attribute.
Harinee G [DevOps Member] Posted new comment 16th July 2024
Harinee G [DevOps Member] commented 16th July 2024
Thankyou, It worked with semicolon!!
