Setting discreets with dependency parameter
Solved1.32K views28th August 2024
Harinee G [DevOps Member]202 15th July 2024 0 Comments
We have a set of dynamic propositions for each channel and we need to select a single proposition accordingly to make the api call. We have added dependency of “Available Proposition” in the “Proposition To Be Slated” parameter inorder to fetch the values.
We are unable to get it as a set of different discreets separately but receiving as a same value in the dropdown. Tried implementing the logic to populate dynamic discreet values from Qaction too but it isn’t working either.
Any suggestions on this one please to get the values separately in the dropdown?
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 28th August 2024
João Severino [SLC] [DevOps Enabler]14.48K Posted 15th July 2024 3 Comments
Checking this docs link dependencyId attribute | DataMiner Docs, I noticed that the remark mentions that the value is supposed to be semicolon-separated ; and in you screenshot I see comma-separated ,
Could you give it a try with the semicolon?
João Severino [SLC] [DevOps Enabler] Edited comment 8th October 2024
Harinee G [DevOps Member] commented 16th July 2024
Thankyou It worked with semicolon!!
Chirangee lal Verma [DevOps Advocate] commented 7th October 2024
what if i need to set these discreet values from a api call data
João Severino [SLC] [DevOps Enabler] commented 8th October 2024
Hi Chirangee,
These cell values are like any other cell, you can use a QAction to do a SetParameter on those with your desired values.
Jens Vandewalle [SLC] [DevOps Advocate]9.85K Posted 15th July 2024 1 Comment
Hi Harinee,
This feature only works with a semicolon-separated list of items as described in dependencyId attribute.
Harinee G [DevOps Member] Posted new comment 16th July 2024
Thankyou, It worked with semicolon!!
