Set property to a service using automation script
Solved769 views5th November 2025#automationscript service
Hari priya Venkatesan [DevOps Advocate]1.06K 18th July 2025 0 Comments
Hi Team,
How can we set and get a new property to a service using automation script. I tried setting like below but on get the property value of the service is coming as empty.
var _serviceInfo = engine.FindService(poolName).ServiceInfo; var proper = new PropertyInfo("Territory", PropertyInfo.DataTypes.Service.ToString(), "GROUP");
_serviceInfo.Properties.Add(proper);
Jorge Dias [SLC] [DevOps Enabler]5.31K Posted 18th July 2025 0 Comments
Hi Hari,
Class Service in Automation scripts has a method for that, SetPropertyValue.
E.g.: See Method SetPropertyValue | DataMiner Docs
